MAG-ic Probe WiFi thickness gauge
Item: #T0450W
MAG-ic Probe WiFi
Luthiers craft fine wooden instruments and understand that the voice and tone of the final instrument will largely depend on carefully planned thicknesses of the tone wood. MAG-ic Probe has been a trusted electronic thickness caliper used by many Luthier’s and other craftsmen since 2012. MAG-ic Probe allows you to measure thicknesses of materials in places where standard calipers cannot fit and also allows you to record your measurements to a computer picture of the instrument and even produce a color contour map.
New for 2021! – MAG-ic Probe can also display the measurements on any phone, tablet or computer that has WiFi capability.
How Does it work?
MAG-ic Probe is a small electronic device that can measure the thickness of non-ferromagnetic materials by using a target magnet. The magnet is placed on one side of the material and the MAG-ic Probe on the other side. The magnet is attracted to the MAG-ic Probe so the measurement will be the thickness of the material at the probe location.
Ideally suited to measuring the thickness of the wooden plates that make up many musical instruments, the magnet can be placed inside the instrument body where standard calipers cannot reach. When the probe is moved along the outside of the instrument, the magnet will follow and will even jump over reasonably sized braces.
MAG-ic Probe is also extensively used in the plastics and composites forming industry.
There are a number of options for displaying or recording these measurements.
1) MAG-ic Probe Software
The free MAG-ic Probe Lite software will allow you to upload a picture of the instrument to your computer. Simply move and aim the mouse pointer at the location on the picture where you are measuring with the MAG-ic Probe, and the measurement will be recorded on the picture. You can map the entire surface of the instrument in this way and print or save the measured image for a permanent record.
The optional MAG-ic Probe PRO software goes further by allowing your measurements to be displayed as a color contour map of the instrument. This makes it easy to instantly see the contour of the plate for progressive shaping or comparative analysis.
2) Display measurements on any WiFi device.
If you do not want to record your measurements and just want to display the measurements as you are shaping or analyzing an instrument, MAG-ic Probe WiFi will now connect to any phone, tablet or computer that has WiFi capability and display the measurements without downloading any apps.
Simply join the MAG-ic Probe WiFi, open the browser on your device and connect to see your measurements in real time.
More information on the MAG-ic Probe website.
$ 598.80
